Requirements
A project log for Home weather station
IoT sensors to capture the weather. I also want to record, store and graph the data.
lee-stephensLee Stephens 08/22/2018 at 13:110 Comments
Let's split the requirements into three.
First, outside the house:
Name Description Type
Temperature Record the current temperature to a minimum of 0.5 of a degree celsius Must
Humidity Record the humidity as a percentage Must
Pressure Record the pressure in millibar Must
Wind speed Record the average wind speed over a ten minute period, record the highest gust over a 0.25 second period1 Should
Wind direction Record the average wind direction over a ten minute period Should
Rainfall Record rainfall in mm Should
Sunshine Record minutes of direct sunshine Should
Unattended operation The device should need no physcial attention. Obviously there will be a need for maintenance, but this should be kept to a minimum Should
Low cost On the basis that it may be damaged or stolen, it would be good to keep the costs low Should
Battery powered Be capable of being powered by batteries for an extended time period. Must
Solar charge Use a solar cell to recharge the battery, hopefully to avoid the need to change the batteries Should
Aesthetically pleasing The sensors should be housed in an aesthetically pleasing housing, suitable for the garden Should
Able to cope with being outside Electronics will need to be kept dry, power must be supplied even in low temperatures. Must
No local storage Recordings should be sent into a central service for long term retention and visualisation
Should
Secondly, the data storage system:
And finally, the visualisation and end user experience:
