Pyxel is now working on the RPi
A project log for Pyxel Paradise
A DIY mini arcade cabinet that can run games built using Pyxel (https://github.com/kitao/pyxel) on the Raspberry Pi.
rkrishnasankarkrishnasanka 07/31/2019 at 04:500 Comments
In short I didn't do much work to make this happen it was the creator Pyxel who in his/her infinite wisdom decided to replace glfw as a dependency and decided to make sdl2 the base framework. The main trick to get half decent frame rate was that I killed the entire desktop manager beforehand.
