Nearing Completion
A project log for Persistence of Vision LED Matrix
Because every project needs a twist.
Matthew James BellafaireMatthew James Bellafaire 10/09/2018 at 02:400 Comments
Spent some more time on this over the weekend. The matrix was attached to some cheap board I had lying around cut into a half decent circle. the board doesn't really have any issue with vertical wobble which was my biggest concern, however it does still vibrate a decent bit at a high speed. after constructing the entire thing, I decided the top of the matrix needed some more support, so naturally fishing line was the perfect solution; it's strong and clear making it impossible to see when spinning. as for the balancing of the thing I knew this would be difficult, for the most part the foam stops on the bottom stop it from sliding around too much and it stays put at the speed I’m usually running it at, but it could be better. There are also ball bearings hot glued to the board to balance it.... it works... what more do you want?
I sped up the code some more on the control board, it had to be slowed down during development due to some strange power issues I was having which is a hilarious story in hindsight. Either way I’ll need to commit a few more hours at some point soon to code optimization to get this thing working ideally. Also need to program in some extra patterns for this thing so it's not only displaying 2 images all the time.
Additionally, I had to adjust a few of the 3d printed gears, specifically the smallest one attached directly to the motor. The gear was way too tall, and not giving enough thread to the nut for it to hold properly. quick rework and a 20-minute print and we were back up and running. also changed the large gear to give it more clearance on the aluminum stand.
Here's where the project stands:
what needs to be done:
I strongly recommend turning your volume down before playing this video
also, lots of flashing lights
