Matrix_Program_Final.zipThe final (working) code files that make the magic happenZip Archive - 7.05 kB - 02/24/2019 at 17:49 |
MatrixArrayGenerator.javajust draw the images and this will handle the tedious parts.Java Source File - 9.18 kB - 10/15/2018 at 21:55 |
small pulley.stlSTL file for small pulley gear which attaches to motorStandard Tesselated Geometry - 452.76 kB - 09/30/2018 at 17:34 |
primary gear.stllarger gear with space for 1/4" ball bearing inserts, designed to use a 5/16 bolt as a drive.Standard Tesselated Geometry - 2.74 MB - 09/30/2018 at 17:34 |
bottom load bearing.stlspacer for end of drive to reduce friction from bolt on the primary gear, has space for 1/4" ball bearings.Standard Tesselated Geometry - 95.10 kB - 09/30/2018 at 17:34 |
top mount.stlmount for platform to hold display matrix, designed to take 1/4" ball bearings.Standard Tesselated Geometry - 258.99 kB - 09/30/2018 at 17:33 |
