Wave Articulation Matrix
Electromagnetic Resonator. Golden Ratio Logarithm.
Golden Ratio Geometric Series of sidebands.
The structure is excited with RF by winding a ''primary'' coil around the tall pointy end of the structure.  The ''secondary'' is the split-ring at the wide end of the structure.
The structure has the form of a Hyperboloid.  Italian physicist and mathematician Evangelista Torricelli called this shape ''Gabriel's Horn''.
It can be thought of as a 3D ''cross - section'' of a shape which exists in more dimensions.  See the book ''Flatland'' by Edwin Abbott Abbott for more insight.
To Do:
1.  Impedance Measurements with VNA
2.  Frequency Sweep and RF average power measurements
Full Design Specs, Videos, Graphics, Mathematical explanations here:
spaz.org/~magi
Wiring Diagram. Class A amplifier fed by signal generator. ''Primary'' winding, which excites the structure, is in series in the Collector circuit of the amplifier.
JPEG Image - 547.91 kB - 08/26/2018 at 20:02
Preview
Decimal dimensions for 4+1 element array. 3 in. OD central element.
Portable Network Graphics (PNG) - 11.83 kB - 08/26/2018 at 20:01
Preview
Algebraic dimensions for 4-element array.
Portable Network Graphics (PNG) - 80.37 kB - 08/26/2018 at 20:00
Preview
Algebraic dimensions for 8-element array.
JPEG Image - 156.24 kB - 08/26/2018 at 20:00
Preview
dimensions-decimal.dxf
Dimensions, Decimal. CAD file. 3 in. OD central element.
AutoCAD DXF - 27.68 kB - 08/26/2018 at 19:59
Download
  • 1 × 2N2222 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × 18 Gauge mild steel
  • 5 × .1 uF capacitor capacitor
  • 1 × 820 ohm resistor
  • 1
    Seam Weld Steel Cylinders
    I had a metal fabricator at All Power Labs in Oakland, CA, make a 5 element array for me.  He charged me $220 for materials and labor.  Once you have the resonator, you will need to make an RF amplifier to excite it.  I made a class A amp.  But if you are just experimenting with just CW, then a Class C amp is fine, and more efficient.
View all instructions
podsko wrote 02/09/2024 at 20:54 point
Their team of experts has extensive knowledge and experience in evaluating gold items. They assess the purity, weight, and condition of your gold accurately, ensuring a fair evaluation https://www.goldankauf-hildesheim.de/.
