PCB Speaker
Open Source Speaker made from a PCB
If you are following my pcb actuator projects you have probably noticed that they beep when placed near a magnet. This is because I am driving them with a frequency that is in the hearing range. It sounds like a very weak buzzer. This is because a speaker is basically made from a coil that actuates a magnet to move air.
This is where my PCB Speaker idea came from. With some modifications, I managed to play music from printed traces!
My PCB speaker is very simple and works just like any other speaker.
Its main components are the magnet and a coil, in this case a flexible printed traces. The vibrations created from the coil pushes the surrounding air to create sound waves. I also tried adding a diaphragm to amplify the music. It also worked with a 1.6mm rigid pcb, having the magnet connected to the diaphragm.
Check out the full video:
RAR Archive - 44.32 kB - 09/20/2018 at 17:29
Download
Gerber.rar
Gerber files for the flexible PCB Speaker
RAR Archive - 45.26 kB - 09/20/2018 at 17:24
Download
  • PCB Speaker Testing
    Carl Bugeja09/20/2018 at 21:39 0 comments
    This video shows how i build the PCB speaker and the test results.
    In this video I have also tested the pcb with plastic cup acting as the diaphragm. This amplified the sound even louder. I also managed to make it work with a 1.6mm rigid pcb, by attaching the magnet to the diaphragm.
  • dB
    Carl Bugeja09/16/2018 at 23:32 0 comments
    To measure how loud my PCB Speaker is I am using an spectrum analyzer app. A maximum 70db level was reached!
  • Coneless Prototype 2
    Carl Bugeja09/15/2018 at 14:59 0 comments
    This is a 3d printed version of the coneless PCB Speaker.
    Full build video coming soon!
  • Prototype 2 with Diaphragm
    Carl Bugeja09/02/2018 at 22:57 0 comments
    Today I have tried making the second pcb speaker prototype with a paper diaphragm. This ended up working worst that the smaller version. I guess i have put too much hotglue making the diaphragm too stiff. I also think that the paper I've used is too thick. Going to try and make a simpler version tmrw.
  • First Prototype
    Carl Bugeja08/30/2018 at 18:03 0 comments
    This is the first cone-less (the cone is actually the flex pcb itself) speaker prototype made from my flexible pcb actuator!
    so far I have only tested buzzy noises. I need to do some redesign of the amplifier to solve some clipping issues.
    https://twitter.com/BugejaCarl/status/1035827203446120448
  • How?
    Carl Bugeja08/29/2018 at 18:44 0 comments
    So how, can I improve it and make it sound better to build the first speaker made from a PCB?
View all 6 project logs
emersonnadia65405 wrote 11/05/2022 at 05:13 point
You Know some information tech related  https://techadvisorguide.com/
Daren Schwenke wrote 09/21/2018 at 01:06 point
I've noticed that stacking rare earth magnets generally doesn't actually increase the field strength in the direction you intended  In some of my test cases, it actually was worse than a single magnet
Don't know the math as to why, but that was the observation.
Morning.Star wrote 09/23/2018 at 05:47 point
Stacking magnets makes a 'chain' of fields, NsnsnsnS where only the ends are free to reintegrate into a circuit. Effectively, because the field is laminar, there will be little pull from either direction except at the ends, which are now far apart and cant make a circuit as easily.
Joining the ends with a piece of ferrous metal completes the circuit and contains the field within the metal, making it non-magnetic externally. With no metal to complete a circuit your magnet stack is therefore weaker than a single magnet because geometry. ;-)
Elliot Williams wrote 08/30/2018 at 11:49 point
Fun idea!  Take it where it goes!
I know for a fact that you can make flexible conductors on plastic sound fantastic:https://en.wikipedia.org/wiki/Magnepan
warhawk-avg wrote 08/30/2018 at 08:36 point
Maybe have one of the coils on a cone, then use opposite currents in the coils..."electromagnet" speaker
