Guitar Toe Tapper
A guitar top tapper using toe power. Made from a wooden spatula, fishing pole tubes, chop stick and rubber ball.
The guitar toe tapper is just another way to use a body part to play some rhythm background to accompany the guitar. We got more body parts, we should use them.
  • Better pulley system
    jimrd10/06/2018 at 07:20 0 comments
    The current cable system just pulls the mallet downwards with the toe but it could probably be improved by using a round pulley rather than a lever. But figuring out the angle would take a bit of work and it would take more force to pull the mallet down than a longer lever. Perhaps just changing the angle of the lever would be the best solution.
    Another problem is that the toe tends to slide forward when tapping the toe and I haven't figured out how to make it stationary.
  • Better sound
    jimrd10/06/2018 at 07:11 0 comments
    I can think of a couple of sound improvements:
    1. The mallet could hit the guitar on the saddle as the sound is deeper and boomier there. Or one could add two mallets, on for the saddle and one where it currently is for a combination of different timbers (pun sort of).
  • Attaching unobtrusively to your guitar
    jimrd10/06/2018 at 07:00 0 comments
    Most folks don't like to screw up (pun) their beautiful wood surface on their prized guitar. And even though my guitar is a cheapie, it still seemed a shame to mess it up. So I simply adapted the mount to use the guitar strap button and a vinyl lock. Of course it could be screwed permanently onto the surface but I like the easy on, easy off functionality.
  • Guitar Toe Tapper
    jimrd08/28/2018 at 07:30 0 comments
View all 4 project logs
  • 1
    Step 1
    Not too much to it: depends on what materials one has around. Mostly one needs a frame to hold the "drum stick" and that turned out to be a wooden spatula  for me. Drilled a hole in the spatula to mount it on the rear guitar strap peg and locked it on with a strip of vinyl.
    Drum stick (chop stick) was epoxied into a fishing pole tube set inside another tube which was cable tied/expoxied to the spatula mount. A rubber band provides some tension for retracting the drum stick.
    Wire connected to foot provides power to pull the drum stick.
    Now I just need to develop a good sense of rhythm.
View all instructions
Ember Leona wrote 10/02/2018 at 23:02 point
I added a toothbrush to a drumstick I think its on youtube search openInvent.
jimrd wrote 10/06/2018 at 07:32 point
Found it. Interesting hybrid guitar. Would like to hear it in tune though.
Ember Leona wrote 10/08/2018 at 05:36 point
Do you have a youtube video theres a way to embed it here. I have a page here about the tiny.cc/snarecapo did you see that video. I wanted to make a wireless kickstand for my guitar. Its pretty much a stereo guitar I recently broke the g -string and made some guitar picks out of it to mimic the jellifish pick
