Having the power
A project log for Blink An LED Entry: BlinkIR
My entry for the Mouser and MacroFAB Blink An LED competition. Blinking modules that interact with each other.
gee-bartlettGee Bartlett 09/08/2018 at 22:360 Comments
I started my initial routing from the schematic I shared before. Much to my disappointment i couldn't settle on a board outline that was beneficial to what i an wanting to achieve without making the board bigger and bigger.
I always wanted to have the individual units powered via sew-able tabs so after soul searching have decided to make this a wearable/soft project.
As you can see in the bottom left of the schematic I have added the pre-mentioned sew-able tabs which will be used for main power.
I intend for these tabs to either be used with conductive thread of which i have some to hand, or to use tradition bus bar or single core bell wire to solder them together in interesting shapes.
