MainBoard.csvDigiKey parts list for the Lasertag case - Resistors, Capacitors and some standard parts *not* included!! (Buy them in bulk is my suggestion)Comma-Separated Values - 400.00 bytes - 01/12/2020 at 16:53 |
Binaries.zipAll files necessary to flash the ESP32.Uses a default WiFi of SSID "Lasertag", static MQTT Server at 192.168.250.1:1883, and it's MAC as PlayerID For now, reconfiguring these parameters requires compiling the firmware yourself - one day I'll add a terminal-based reconfigure Zip Archive - 771.24 kB - 11/10/2019 at 13:02 |
Lasertag_Case.zipAll 3D STL files that are necessary to print a casing.Multi-Material-Capable, for single material printing just leave out transparent and marking sections! x-zip-compressed - 435.41 kB - 10/31/2019 at 15:02 |
KiCAD_R_3.2.zipThe revision 3.2 KiCAD files. Preferably pull them from the GitHub site, but they're here if anyone asks!Zip Archive - 2.39 MB - 09/02/2019 at 19:59 |
