Hackaday.io Hackaday.io
Sign up Log in
360 pixel LED Clock prototype
5050 SMD LED Clock + ESP controller
michael-bestMichael Best
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
739 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
997
0
739
2
Team (1)
  • michael-bestMichael Best
Join this project's team
hardware
ongoing project
led clock
This project was created on 08/29/2018 and last updated 6 years ago.
Description
360 LED pixel RGB clock, made of 6 panels of 60 LEDs each.
Components
  • 360 × TX1818A
Project Logs
Collapse
  • First SMT soldering
    Michael Best • 10/03/2018 at 07:53 • 0 comments
    First SMT soldering ever, the board was a mess going in, but it came out with flying colors.  This was a test of the 1.1mm solder pads for the 5050 leds.
  • LED test boards arrived
    Michael Best • 10/01/2018 at 17:49 • 0 comments
    LED pad size testing boards have arrived from OSHPark, time to try some reflow soldering
  • Solder Pad Test board
    Michael Best • 09/13/2018 at 06:04 • 0 comments
    Testing if I can put the 5050 LEDs quite close together by using a reduced solder pad size.
    Finally got my first board designed and uploaded to OSH Park
    https://oshpark.com/shared_projects/E9llSQ2v
  • LED placement via scripting and modified footprints
    Michael Best • 09/09/2018 at 18:10 • 0 comments
    Finally got mmccoo's KiCad plugins working properly (partially need a particular environment, partially mistakes on my part).
    I need to send out some small prototype boards, I need to see if I can make smaller footprints for the LEDs, the default solder pads are huge, and I wonder if I can get away with smaller ones.
  • LEDs arrive
    Michael Best • 08/29/2018 at 22:19 • 0 comments
    Received the 2000 TX1818A LEDs today, crossed fingers that they will be able to talk a standard protocol.
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
TIL305 remake with SMD LEDs. 0402 and 0201 SMD LED Versions
Project Owner Contributor
reDOT
alexAlex
As you will probably know, this is the famous prop from Doctor Who, the television series from BBC. I just love this thing.
Sonic Screwdriver
davedarkodavedarko
You’ve heard of RGB, now get ready for RRAYLLGTTBB+UV+WWCWBWDW
Metamer SAO
reid-sox-harrisReid Sox-Harris
Blinky leaves, enamel wire trunk, arduino roots
Another LED tree
pP
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "360 pixel LED Clock prototype", please tell us the reason.
Send message
Remove Member
