First SMT soldering
10/03/2018 at 07:53 • 0 commentsFirst SMT soldering ever, the board was a mess going in, but it came out with flying colors. This was a test of the 1.1mm solder pads for the 5050 leds.
LED test boards arrived
10/01/2018 at 17:49 • 0 commentsLED pad size testing boards have arrived from OSHPark, time to try some reflow soldering
Solder Pad Test board
09/13/2018 at 06:04 • 0 commentsTesting if I can put the 5050 LEDs quite close together by using a reduced solder pad size.
Finally got my first board designed and uploaded to OSH Park
https://oshpark.com/shared_projects/E9llSQ2v
LED placement via scripting and modified footprints
09/09/2018 at 18:10 • 0 commentsFinally got mmccoo's KiCad plugins working properly (partially need a particular environment, partially mistakes on my part).
I need to send out some small prototype boards, I need to see if I can make smaller footprints for the LEDs, the default solder pads are huge, and I wonder if I can get away with smaller ones.
LEDs arrive
08/29/2018 at 22:19 • 0 commentsReceived the 2000 TX1818A LEDs today, crossed fingers that they will be able to talk a standard protocol.
