Manual Programming modes
A project log for Memory-Card made of AMD's CMOS UV-EPROMs
The idea is to help you make use of the old and trusted hardware for memory hungry projects instead of wasting money on fancy stuff.
Dave_ Z.Dave_ Z. 10/02/2018 at 22:130 Comments
For hardcore folks there is a hardware programming mode. One can add DIP 16 bit switches to manually enter data into the memory-card. Any ideas or thoughts about this would be interesting.
