Erasing the EPROMs, how-to
A project log for Memory-Card made of AMD's CMOS UV-EPROMs
The idea is to help you make use of the old and trusted hardware for memory hungry projects instead of wasting money on fancy stuff.
dave-zDave_ Z. 10/03/2018 at 08:070 Comments
In case there is a need to wipe the entire EPROM contents, the most easy way is to use the UV-EPROM eraser (pic below).
It has  UV light source inside which will erase everything in minutes. In my case I put my entire memory-bank inside and it is ready to use again. Easy
