Remote Paper Air Rocket Laucher with ESP8266
Launch Paper Air Rockets Remotely from a Web Page
Public Chat
Several years ago we built a Paper Air Rocket launcher after seeing one in operation at Maker Faire in NYC. It uses a cheap electric sprinkler valve and two 9 Volt batteries in series connected to a simple switch with a long wire for launching. The air chamber is made of 2" PVC. We use a small electric air compressor set to 25 PSI to charge it although a bicycle pump can also be used. The rockets themselves are made from paper and masking tape and can fly a couple hundred feet. Since they're so light they simply float to the ground. In this project we'll replace the manual switch with an ESP8266 and a relay and use aREST from Marco Schwartz to control the launch remotely.https://cloud.arest.io/a78c36y/digital/5/1
The Rocket can be launched from anywhere by typing the following command into a browser. This causes Pin 5 on the ESP8266 to go HIGH.
To reset the pin back to LOW to ready the next launch send:
https://cloud.arest.io/a78c36y/digital/5/0
We also controlled the rocket launch by creating an aREST Dashboard. Instructions on how to do this are here: https://arest.io/esp8266-arest-pro
An iPhone app using Thunkable.com also worked but it's just a simple button that tells Pin 5 to go HIGH. More to follow on that.
                                                     Remote Rocket Launch.
                                                         aREST Dashboard
                    Simple Thunkable App used to Launch Rocket from an iPhone.
air_rocket_example.ino
ESP8266 Code
ino - 1.20 kB - 09/01/2018 at 21:38
Download
View all 7 components
View project log
