YakShaveriOS3.pdLatest version of the Yak Shaver patch, which should work standalone as long as you have the freeverb~ extension.pd - 40.15 kB - 10/02/2018 at 21:28 |
freeverb~.zipFreeverb~ is needed for reverb in the Yak Shaver. Unzip in the same directory or install in Pure Data using Deken.Zip Archive - 31.90 kB - 10/02/2018 at 21:26 |
samples.zipThe default set of WAV samples.Zip Archive - 9.98 MB - 10/02/2018 at 21:25 |
PhysicalFluxlyNetReceive.pdThis is the Yak Shaver patch with the inputs hooked up to a netreceive object to grab data from the gyro over UDP.pd - 42.75 kB - 10/02/2018 at 21:23 |
