Hydroponics Sensor
ESP32 based Hydroponics Sensor (Water Flow, Water PPM, Water pH, Water Temperature).
Public Chat
WeMos LOLIN 32 board hooked up to:<br><br>DS18b20 Water Temperature Sensor,<br>Gravity Analog pH Sensor (<a target="_blank" rel="noopener noreferrer" href="https://www.dfrobot.com/product-1110.html">https://www.dfrobot.com/product-1110.html</a>)<br>Gravity Analog EC Meter (<a target="_blank" rel="noopener noreferrer" href="https://www.dfrobot.com/product-1123.html">https://www.dfrobot.com/product-1123.html</a>)<br>Water Flow Sensor<br><br>I used a modified EC probe based from the Three Dollar EC - PPM Meter by Michael (<a target="_blank" rel="noopener noreferrer" href="https://hackaday.io/project/7008-fly-wars-a-hackers-solution-to-world-hunger/log/24646-three-dollar-ec-ppm-meter-arduino">https://hackaday.io/project/7008-fly-wars-a-hackers-solution-to-world-hunger/log/24646-three-dollar-ec-ppm-meter-arduino</a>)
This was a freelance job offered to me, unfortunately, I can't share the finished code.
This project was supposed to be a test of concept if automating the sensors in a hydroponics farm will work while still maintaining the accuracy of the readings over-time.
The data gathered was also published to the a cloud server for viewing even if the farm was located at a remote area.
  • 1 × WeMos LOLIN32 https://wiki.wemos.cc/products:lolin32:lolin32
  • 1 × Gravity Analog PH Module https://www.dfrobot.com/product-1110.html
  • 1 × Gravity: Analog Electrical Conductivity Sensor https://www.dfrobot.com/product-1123.html
  • 1 × DS18b20 Water Temperature Sensor https://www.sparkfun.com/products/11050
  • 1 × Water Flow Sensor https://www.dfrobot.com/product-1531.html
  • 1
    Some notes
    The ESP-32 board pins operate in 3.3v levels while the Gravity pH and EC sensors operate in 5V. I inserted a simple voltage divider to shift 5v to 3.3v levels on the signal pins.
View all instructions
mihaibogdan.georgescu wrote 04/29/2019 at 10:16 point
Hello, I was looking to build the same thing, can you please share your code?
