Example Code Wiki Page Updated
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 12/01/2018 at 10:280 Comments
The Example Code page in the STM8 eForth Wiki contained some seriously "under-hyped" projects, libraries and demos.
Some of the demos really deserve to be more "accessible" (search engines algorithms don't rank the beauty of code ;-) ). Here is one from the attic:
STM8 eForth W1209 based HC-SR04 Ultrasonic Distance Display
This code uses a W1209 and a HC-SR04 HC-SR04 (or a compatible device for $0.75) to create an ultrasonic distance display. By controlling the relay, building an approximation detector, fill level controller, or some other embedded control device is easy.
Also see the discussion in Issue #136:
I received a HC-SR04 and connected it to a W1209 through PC3/TIM1_CH3 (the set key input). With the STM8S Timer1 puls-width measurement feature it works surprisingly well (up to about 3m). The W1219 doesn't have an input that's equally well suited, but I'm sure that something can be hacked with PD4/TIM2_CH1 (although the background task might have to use TIM1 then).
