An STM8 eForth WS2812 Demo
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 12/24/2018 at 12:450 Comments
Controlling the WS2812 with STM8 eForth was something I've had on my to-do list for a long time. The lore of W2812 timing is already long and twisted, and any new implementation, it seems, has to add a bit to it :-)
Mine is the following:
   Do it the Aristotle way: Relax the timing but maintain the balance!
I coded the inner loop for a byte transfer and the bit timing in assembly (in a self balancing way). The outer loop is coded in Forth. The result is quite compact:
  : WS2812 ( a1 a0 -- )
     DO  [
           $1601 ,         \     LDW  Y,(1,SP)
           $90F6 ,         \     LD   A,(Y)
           $88   C,        \     PUSH A
           $A608 ,         \     LD   A,#8
           ] [ 1 PB_ODR 4 ]B! [
           $0901 ,         \     RLC  (1,SP)
           $9D  C,         \     NOP
           $2504 ,         \     JRC  1$
           ] [ 0 PB_ODR 4 ]B! [
           $9D  C,         \ 1$: NOP
           $9D  C,         \     NOP
           $9D  C,         \     NOP
           $2404 ,         \     JRNC 2$
           $9D  C,         \ 2$: NOP
           $4A  C,         \     DEC  A
           $4D  C,         \     TNZ  A
           $26E5 ,         \     JRNE 0$
           $84 C,          \     POP  A
     ] LOOP ;
I tested the code by comparing the sensitivity of the reshaped bit timing at the output of the WS2812B.
The code and some findings are here.
