Starting to work on the HC12
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
ThomasThomas 05/01/2017 at 18:428 Comments
The HC12 is a Si4463 based RS232-RF modem in 433 ISM band. Compared with the average garage door remote RF solution the Si4463 is much more advanced (range, modulation modes, immunity to noise). It has so many features that the normal way to program it is to use a code generator provided by Silicon Labs, the manufacturer of the chip.
The other chip on the board is an STM8S003F3P6, and that's why I write about it. Some time ago @ajlitt forked the STM8EF repository to work on the HC12. He did the reverse engineering, and wrote first code to make the STM8S talk to the Si4463 (a mix of board-support code, and Forth). However, he had planned to implement a packet radio protocol that needs more RAM than the STM8S has to offer.
I have a much more humble use case: bring Forth into the STM8S of the HC12, and have it communicate with an off-the-shelf HC12 through the Si4463 radio.
Some time ago I ordered 3 x HC12 modules that now have the following roles:
The HC12 connected to the logic analyzer is necessary to understand, and re-implement the Si4463 API calls and parameters.
I now implement the initialization, and the communication routines. There is an "issue", and some docs on GitHub.
nateshkannan.s wrote 02/16/2019 at 09:58 point
Hi guys,
i am currently working with HC12, if it is have any data available pin like a DTR.
i am trying to upload the sketch wireless at long distance so i choose HC12. but i can't upload the sketch to my Arduino uno because that boot loader need reset for enter the sketch upload.
If anyone have idea about my concept please let me know,
thank you
with regards
kannannatesh
Lars Brinkhoff wrote 09/18/2017 at 14:14 point
It's a bit confusing when there's also an mcu called HC12 from Mot... I mean Free... I mean NXP.
jaromir.sukuba wrote 09/18/2017 at 14:23 point
Did you mean Qualcomm?
Lars Brinkhoff wrote 09/18/2017 at 18:14 point
Yikes, I didn't even know Qualcomm was bidding to buy NXP.  Doesn't look like a done deal though?
richard wrote 09/18/2017 at 07:14 point
I've got a pair coming.And a logic analyser. Pure coincidence but now perhaps serendipity.
Thomas wrote 09/18/2017 at 18:35 point
I bought 3 of them: one to hack code, one to communicate with, and one to trace the original SPI data stream (using a logic analyzer). A couple of things with "higher priority" came my way, but at least I can share some traces.
Arsenijs wrote 05/12/2017 at 22:00 point
I just found the HC12, came to this project to tell you it has an STM8, but it appears you guys got here first =)
Thomas wrote 05/13/2017 at 06:37 point
Hehe nice! Get a pair of them - it's fun!
