W1209: Measure the Internal Resistance of Lead Acid Batteries
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
ThomasThomas 08/12/2017 at 11:310 Comments
@richard published a HaD project with an interesting new use case for the notorious W1209 thermostat: measure the internal resistance of lead acid batteries in a battery reconditioning set-up. All the hardware features of the W1209 are re-used: relay, LED display, keys, sensor input, and even EEPROM storage!
On Richard's project page there is also a video clip of the device!
The resistance measurement uses the relay and a 1A constant current circuit (a 7805 5V regulator and a 5R resistor), and calculates the resistance by comparing the open-circuit battery voltage with the voltage under load.
Check out Richard's blog - there is a ton of great hacks!
