Forth Throwies
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 03/27/2017 at 20:484 Comments
STM8S003F3P6 µCs are cheap (OK, this isn't the first time you read that). Some time ago @K.C. Lee used off-the-shelf TSSOP adapter PCBs as a simple µC board. A great idea! Like that one can make a Li coin battery powered board for about $0.60:
Component@$/unit
STM8S003F3P6100.24
PCB SOP/TSSOP/DIL20100.11
2x 1uF ceramics capacitor
1000.02
CR2025100.13
Li battery holder100.10
Like K.C. I added the essential components (2x 1µF capacitors) to the unused SOP20 pads on the other side, and did a test with the SWIMCOM image, and it worked nicely!
In "active halt" state it can run quite some time as an environmental data logger. I have some ideas for low-bandwidth environmental sensors that can be deployed, and recovered later on. I'll call this a "sensor throwie", since it's not a bit loss if some of them can't be recovered (missing in action. so to say).
K.C. Lee wrote 04/01/2017 at 13:41 point
STM8S brown out detector has a 2.8V (max) threshold.  This doesn't give a lot of head room.  You should use a larger decoupling cap as those Li coin cells have high internal resistance.
Those super glue bottle caps can be used for housing these PCB if you round off the corners a bit.  A piezo disc also fits.
Thomas wrote 04/01/2017 at 17:07 point
You're right, the brown out detector is the limiting factor, and cheap STM8L0x devices aren't available on the hobby market. Turning to STM32F030 might be an option (1.8 .. 3.6V). I've also been thinking about a self-boosting circuit using the brown-out detector as a comparator (with NRST as the output). This just might be crazy enough to work ;-)
Good idea to look in the garbage for throwie housing. I guess I will have to look for different items, though. Garbage is different over here.
K.C. Lee wrote 04/01/2017 at 21:37 point
You would want the brownout detector as a bootstrap until you can bring a timer peripheral online.
Medicine caps, large bottle caps etc.
Eric Hertz wrote 04/03/2017 at 01:30 point
hah, that'd be a hack-and-a-half!
