Release v2.2.11: Board XH-M188, ALIAS Feature
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 06/04/2017 at 12:090 Comments
Board XH-M188 (Issue #29)
@Elliot Williams contributed initial support for the board XH-M188. Thanks a bunch!
After removing the socketed 7S-LED display the board offers a GPIO breakout, and standard RxD/TxD communication ports.
ALIAS Feature (Issue #26, #27)
@RigTig needs more free Flash memory for his main project. As Forth headers require a lot of memory he proposed loading Forth headers to RAM. With the help of some minor changes to forth.asm (e.g. enhanced NAME>) about 2000 bytes of Flash memory can be recovered. Please refer to the discussion in #27.
Words last and NAME> used in RECURSE example linked
The recursive programming example requires last and NAME> to be exposed. That's fixed now.
Binaries are here - Happy hacking!
