v2.2.17.pre: Bug fixed. CI with Test Automation on Track
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 09/30/2017 at 12:060 Comments
The bug in $" (compile in-line string) found by @Eelco is now fixed, but there is still no revision information in "HI" (this will be part of the final release).
However, there is some important progress in the QA department: automated quality assurance, using SiL and virtual hardware, is on track!
The following now works:
I'm quite happy with the progress but there still is a lot left to do:
Unless uCsim gets a much better hardware emulation, the following tests currently require a "HiL setup":
I guess that such a HiL setup, maybe Raspberry Pi based, can be used from within Travis-CI.
