W1209 "Lemons"
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 02/17/2018 at 22:510 Comments
Several people received more or less compatible W1209 clones from vendors:
@richard helped raise the issue, and provided a Wiki entry that helps you telling clones apart. Unfortunately vendors don't always show the variant you receive.
If you get one of the compatible clones you're lucky, and also the resistor variants are easy to deal with. Fortunately Zoltan documented the common anode variants, and provided the board configuration W1209-CA.
If you get a W1209 with a Nuvoton chip the only thing you can do is replace the µC, and call the vendor names, of course.
