Disclaimer: Use the information provided here at your own risk. I do not take any responsibility for any resulting damage.
Pin outs
PIN #
name description
1 RED Red video
2 GREEN Green video
3 BLUE Blue video
4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC
5 GND Horizontal sync ground
6 RED_RTN Red return
7 GREEN_RTN Green return
8 BLUE_RTN Blue return
9 KEY/PWR formerly key, now +5V DC, powers EDID EEPROM chip on some monitors
10 GND Vertical sync ground
11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC
12 ID1/SDA formerly Monitor ID bit 1, I²C data since DDC2
13 HSync Horizontal sync
14 VSync Vertical sync
15 ID3/SCL formerly Monitor ID bit 3, I²C clock since DDC2
Table 1: Pin out of a female DE-15 connector functioning as a VGA output from wikipedia
PIN #
description
1 Audio output (right)
2 Audio input (right)
3 Audio output (left/mono)
4 Audio ground
5 Blue ground
6 Audio input (left/mono)
7 Blue
8 Status & Aspect Ratio
0–2 V → off
+5–8 V → on/16:9
+9.5–12 V → on/4:3
9 Green ground
10 not used in this project
11 RGB Green
12 not used in this project
13 Red ground
14 pin 8 ground
15 Red
16 RGB selection
0–0.4 V → composite
1–3 V → RGB
17 Composite sync ground
18 pin 16 ground
19 Composite sync output
20 Composite sync input
21 Shell/Chassis
Table 2: Pin out of a SCART connector from wikipedia
Power source
Many components used in this project require a 5V power source. You have several alternatives:
  • If you are generating the VGA signal using a PC you can get it from its internal power supply. You can see the pin out here.
  • If the system used to generate the VGA signal has USB ports you can get it from one of them. You can see the pin out here.
  • You can use an external power supply. Any cell phone charger with an USB connector should be adequate.
  • If the device generating the VGA signal is not very old it will probably provide 5V through the pin 9 of the DE-15 connector. If it complies with the DDC host system standard it will supply at least 300 mA, which is enough to power all the components used in this project.
Horizontal frequency monitoring
As mentioned, the frequency of the horizontal scanning of a CRT TV is about 15.7 KHz. If the frequency composite sync signal is higher the image will not be properly displayed, but it will probably not damage your TV since the actual scanning movement of the electron beam is directed by internal deflection generators. However, if you are using a very old monitor or just do not want to be annoyed by a messed image you can use a circuit to blank the screen when the horizontal frequency is not correct. You can see these circuits in Tim Worthington's guide. I have not tested it, but I suggest you to use the solution based on the PIC12C508 since it has only a few connections to solder. The PIC will monitor the horizontal sync signal and will generate a logic output called ENABLE. If the horizontal frequency is OK the PIC will set ENABLE high. Otherwise it will set it low. This ENABLE signal can be used in several ways:
  • Blank the screen by setting the RGB selection signal to  ground when the frequency of the horizontal sync signal is wrong
  • Disable the composite sync signal when the horizontal sync frequency is too high
  • If a DC-DC converter is used to generate the status signal, shut it down
The use of the ENABLE signal is described bellow....
