Solar-powered flashing LED heart pendant
for Mouser and MacroFAB Blink An LED competition
Starting from
$39.99
bobricius has 2082 orders / 91reviews
Ships from Slovakia
Whats it is make special MacroFab Design Contest: Blink an LED Sponsored by Mouser Electronics ???
- wearable
- innovative
- effective
- easy replicable
- with good coating survive doomsday
- flash indoor
- indoor voltage from solar cells is only 1V and 1uA, it is harvesting masterpiece
Led flasher work as charge pump, multiply input voltage twice to get 2V pulses
Advantages compared to other designs.
  • discrete components, no special QFN chip (two standard transistors, 5 resistors and 3 capacitors)
  • based on charge pump design
  • work indoor, no direct sunlight required !!!!
  • startup current is less than 1uA, it is much lower than on commercial harvesting IC or designs
Why again BPW34 aka solar cell?
  • PLASTIC, harder to break
  • easy to buy, it is smallest commercially available solar cells
  • there is no way to get small non Chinese solar panel
  • IXYS solar bit are discontinued
  • Panasonic amorton are made from glass and is not easy to buy
As you can see on video, led flashing in room light.
I created all on breadboard and about month experimentally adjust components values to get best performance.
Board image
Bill of materials with Mouser links to each component:
OFF COURSE IT WORK WITH BIGGER COMPONENTS CASE (0805, 1206) OR TH COMPONENTS
  • 1 × MMBT2222ALT1G Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × MMBT2907ALT1G Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × any 3528 RED LED
  • 2 × 0603 resistor 10M
  • 2 × 0603 resistor 22K
View all 9 components
  • 1
    Just assembly and enjoy
    It is crazy simple device, no programming, no micro-controllers, old fashion passive design,  just solder components and enjoy :D
View all instructions
Kaspar Emanuel wrote 01/31/2019 at 15:09 point
These are really nice, is there a schematic so I can better understand the circuit?
phuzybuny wrote 11/28/2022 at 04:38 point
OP has a similar project https://hackaday.io/project/85457-ultra-low-power-energy-harvester-from-bpw34 with a schematic and image of a test schematic. However, the two schematics are slightly different (e.g., resistor values, placement, etc.).
