Franconian Word Clock with RPi zero W
Simple LED Design Clock with a Raspberry Pi Zero W using Python and pigpio-lib
JKJK
Public Chat
A real word clock with 24 LEDs controlled by a Raspberry Pi Zero W (RPi) in Python.
The goal:
Reduce the additional components to an absolute minimum. No additional PCBs or parts (shift register, port expander, driver, resistors, …) are needed.
The Result:
Just glue 24 strong LEDs behind/below acrylic plates with the words and wire them directly to the RPi pads. The soldering is reduced to cables between LEDs and RPi. The clock can be powered over a Micro-USB cable from a mobile phone power supply.
The Features:
• The transitions between time values are blended via PWM for all LEDs.
• The current time is received via NTP over WiFi.
• Two free pins for additional gadgets (I²C, GPIO).
The words:
In the German language it is common to say „halb zwölf“ (translated: „half twelve“ or „half of twelve“ = 11:30h).
In a little area in the south of Germany – Franconia – you can hear people saying consequently „viertel zwölf“ („quarter twelve“ = 11:15h) and „dreiviertel zwölf“ („three-quarter twelve“ = 11:45h). In the other parts of Germany the Franconians often are not understood.
It is also common to say „fife to twelve“ (11:55h) and „fife past twelve“ (12:05h). This is equal in German and English.
In final consequence it is logical to say „zwei vor dreiviertel zwölf“ („two to tree-quarter twelve“ = 12:42h = 23:42h)
The clock is using this Franconian schema/wording to show the time with 24 elements/LEDs.
Most other so called “word clocks” are using illuminated characters and get a time in a resolution of 5 minutes. The Franconian clock uses 24 complete words and gets a time resolution of 1 minute!
To implement this wording you use 4 groups:
  • Numbers 1 to 7 for minutes
  • “to” and “past”
  • “quarter”, “half” and “three-quarter” (the “quarter” is shared)
  • Numbers 1 to 12 for hours
Easy to Build
Reducing the electronic components to the RPi, the LEDs and the wires between them, you can concentrate on form and design.
LEDs
Using high luminance LEDs with a max. of 3.1 volts. Any color you like.
The current to the LEDs is limited by the RPi to 8 mA per GPIO via software. Possible values are 2, 4, 8, 16 (higher than 8 is not recommended). The usual resistor in line of the LED is not needed!
Powering
The RPi can be powered over a Micro-USB cable. Use a mobile phone power supply (for USB) or a nearby PC/server with USB.
The typical current at the 5 volts line is about 100 mA with peaks up to 300 mA when WiFi fires.
Design
Following the rules of the wording you are free to sculpt, form and place the illuminated words with any material and technique.
Upgrading
To use low voltage bulbs (5...24V), you can add 3 driver ICs like the ULN2803 directly to the RPi without a level shifter.
Pins for I²C are left free for additional IoT gadgets for e.g. temperature, humidity, luminosity, presence, notification...
Decisions
Why RPi?
Pros:
  • The RPi can use up to 26 GPIO pins directly without an additional port expander or shift register. Most smaller/cheaper controllers do not have enough pins to drive the 24 LEDs directly.
  • The RPi has a built in current limiter on the GPIO pins. Resistors in line to LEDs are not necessary.
  • The RPi Zero has on-board WiFi to get the correct time via NTP. No external RTC needed.
  • The RPi Zero has additional power and pins to run additional IoT features.
  • Faster development (and code change).
Cons:
  • Linux! Many steps to setup the controller. See chapter on GitHub Wiki...
  • Linux! Potential security leaks to your local network.
  • A little more expensive (about 20 Euro incl. MicroSD) than an ESP8266 (<7 Euro).
Why pigpio-lib?
Pros:
  • This lib can handle software PWM for ALL 26 GPIOs without any glitches.
  • Faster than BCM-lib.
  • Development and debugging can be done on your PC with remote control of the RPi GPIOs over the network.
  • Implementation for several programming languages available.
Cons:
  • pigpio-deamon permanently eats  7...10 percent of CPU time independent of how many GPIOs or PWMs are active.
  • The lib documentation has room for improvement.
  • 1 × Raspberry Pi Zero W
  • 1 × MicroCD Card with Raspian, Python, pigpio-lib and clock program
  • 24 × Strong LEDs any Color you like. Max 3.1 Volt
  • 1 × 5V Power Supply e.g. Mobile Phone Charger with Micro-USB Cable
  • 1
    RPi Pinout
    Pins 7 to 40 should be used for the clock LEDs.
    Pins 1 to 6 are free for optional I²C devices and other GPIO stuff.
    Default Pinout:
    Note: The LED to GPIO mapping can be easily changed in source code
  • 2
    RPi Software
    See detail description on https://github.com/fablab-wue/piClock/blob/master/prepare.md
    In short:
    • Setup network/WiFi
    • Disable SPI, 1-Wire, Serial
    • Install Python3, pigpio-lib
    • Download source from GitHub
    • Autostart at boot the ~/piClock/franconian.py
    Linux experts will configure the RPi in no-time. Less experienced users (like me) needed more time for configuring than for wood-working and soldering.
View all instructions
