test_output.csvThis is the CSV file describing the test waveform I used.Comma-Separated Values - 676.63 kB - 09/15/2018 at 19:11 |
test_waveform_generator.zipContains the C++ source code to generate the test CSV file (formatted for a Siglent SDG2042X model AWG). Compile with "clang++ -o main main.cpp siglent_awg.cpp", run with "./main".Zip Archive - 2.80 kB - 09/15/2018 at 19:09 |
GEQ_1 BOM.xlsBill of materials, as generated by Mouser Electronicsms-excel - 23.00 kB - 09/14/2018 at 20:07 |
GEQ-1.zipKiCad PCB Project & gerber files for the boardZip Archive - 257.96 kB - 09/14/2018 at 20:01 |
