Progress till 21-11-2018
A project log for Remote Controlled Slide Changer
RF-based remote-controlled slide changer using LPC2148 microcontroller as HID interface
sambit-patraSambit Patra 11/26/2018 at 08:370 Comments
Changed the report format of usb descriptor to keyboard format.
Checked that micro-controller is being detected as hid keyboard interface device.
For different scan-codes  of keyboard,functionality is checked in the pc.
Changed the code in remote.c file for appropriate working of remote controlled slide.
-- TO DO --
Interfacing the remote-controller to pc through micro-controller and testing the slide change for appropriate key press.
