A simple 16 bit instruction set
A project log for 1 Square Inch TTL CPU
A microprocessor built with TTL chips. In one square inch.
roelhroelh 09/15/2018 at 14:230 Comments
To have a quick start, a very simple instruction set was chosen. It is based upon the zero-page addressing mode, and most operations work on 16-bit values. This makes it a 16 bit processor with an 8 bit bus. There is a single 16-bit accumulator, surprisingly called "A", and a 16-bit PC. A single instruction can load or save the 16 bits in A from or to the zero page. Also, the zero page values can be used as a pointer (as in the 6502) . This makes indirect load or store possible. There is an increment-by-two that works with a table in external ROM. All instructions are two bytes long. The opcodes are simply the 8-bit start addresses in the microcode, 16 bytes apart, giving a maximum of 16 opcodes. It is not an efficient opcode since only 4 of the 8 bits in the opcode are used.
Note that these instructions can be (almost) freely chosen, but that they must be supported/interpreted by the microcode program. To support this simple instruction set, the microprogram is less than 256 bytes.  4096 bytes are available, so a much more complex instruction set can be supported.
EXTERNAL MEMORY:
0    - 3FFF  RAM
4000 - 7FFF  I/O
8000 - BFFF  ROM
  'A' is a 16 bit accumulator in RAM at 0x0004(lsb) and 0x0005(msb)
  PC is a 16 bit location in RAM at 0x0002(lsb) and 0x0003(msb).
           (Execution starts at 0x8010)
  Temp is a 16 bit temp storage in RAM at 0x0006(lsb) and 0x0007(msb)
  reset vector: Address 0x8000 in ROM contains fixed value 0x10,
                address 0x8001 contains 0x80
  address 0x8002 contains 0x00
The following opcodes are defined. All opcodes are followed by
 a single operand byte.
0x20  LDB AL,#I8  ; 8 bit immediate load AL, AH will be set to zero.
0x30  LDB AH,#I8  ; 8 bit immediate load AH
0x40  LDW A,Z    ; 16 bit load from a zero page location
0x50  STW Z,A    ; 16 bit store to a zpage location
0x60  LDW A,(Z)  ; 16 bit indirect load (address pointer in zero page)
0x70  STW (Z),A  ; 16 bit indirect store (pointer in zero page)
0xe0  LDB A,(Z)  ; 8 bit indirect load (address pointer in zero page)
0xd0  STB (Z),A  ; 8 bit indirect store (pointer in zero page)
0x80  BR label   ; replace lower 8 bits of PC
0x90  BRM label  ; replace lower 8 bits of PC if bit 7 of ACC is 1
0xa0  BRP label  ; replace lower 8 bits of PC if bit 7 of ACC is 0
0xb0  PAGE label   ; jp to another page, label is 16 bit (lower 8 bits
                   ;     must be zero, so it's a 2 byte instruction)
0xc0  INCD A     ; 8-bit increment-double (increment-by-two) accumulator (needs table in
             ; ROM at 0x8100)
             ; The second instruction byte has msb of table address
             ; The same table is used to increment the PC.
0xc0  DECD A      ; 8-bit decrement-by-two accumulator (needs table in ROM
             ; at 0x8200)
