This project is being  programmed on arduino to make it function properly and to make it show percentages on MIT app inventor. This happens with the use of bluetooth module which gives connection so that the arduino could send the information to the app. We have used 2 sensors to show values of water, humidity and temperature that are present in the crop. The temperature and humidity is shown on the app by humidity temperature sensor and the percentage of water by moisture sensor.  Also we have used tinkercad to make our structure and 3D print it.
