Longboard Tutorial.docxHere's the entire Guide.application/vnd.openxmlformats-officedocument.wordprocessingml.document - 2.20 MB - 09/15/2018 at 11:59 |
Shorty (Dropthrough breiter).f3dhere's the model as a . f3dfusion - 746.15 kB - 09/15/2018 at 12:46 |
ShortyCompatible (breiteres dropthrough).stephere's the 3d model as a .step file, compatible with Rhinocamstep - 256.79 kB - 09/15/2018 at 12:47 |
ShortyCompatible (breiteres dropthrough).3dmbakHere's one file for RhinoCAM, in case you need it. I dont know wheter you need edm or .3dmbak, so I upload both.3dmbak - 1.22 MB - 09/15/2018 at 12:58 |
ShortyCompatible (breiteres dropthrough).3dmHere's one file for RhinoCAM, in case you need it. I dont know wheter you need edm or .3dmbak, so I upload both.3dm - 1.25 MB - 09/15/2018 at 12:56 |
ShortyCompatible (breiteres dropthrough)_Horizontal Roughing Griffe (1).ncthese are the already exported .nc files for milling. Roughing for the handles. Also cuts the handleholesNetwork Common Data Form (NetCDF) - 7.22 kB - 09/15/2018 at 12:49 |
ShortyCompatible (breiteres dropthrough)_Horizontal Finishing griffe (2).ncthese are the already exported .nc files for milling. Horizontal finishing of the handle.Network Common Data Form (NetCDF) - 54.70 kB - 09/15/2018 at 12:49 |
ShortyCompatible (breiteres dropthrough)_2 1_2 Axis Profiling Dropthrough (3).ncthese are the already exported .nc files for milling. Cuts theholes for the dropthrough, where your axis goes through. Network Common Data Form (NetCDF) - 10.95 kB - 09/15/2018 at 12:49 |
ShortyCompatible (breiteres dropthrough)_Horizontal Roughing Kante (4).ncthese are the already exported .nc files for milling. Horizontal roughing of the edges.Network Common Data Form (NetCDF) - 5.56 kB - 09/15/2018 at 12:49 |
ShortyCompatible (breiteres dropthrough)_Horizontal Finishing Kante (5).ncthese are the already exported .nc files for milling. Horizontal finishing of the edgesNetwork Common Data Form (NetCDF) - 100.27 kB - 09/15/2018 at 12:49 |
ShortyCompatible (breiteres dropthrough)_2 1_2 Axis Profiling Board (7).ncthese are the already exported .nc files for milling. This cuts out the board. Number 6 was skipped because it didn't work out.Network Common Data Form (NetCDF) - 19.84 kB - 09/15/2018 at 12:49 |
