WHAT IS THIS
Useless Nixie Device "is a device which has a function but no direct purpose". The device allows you to connect 16 different sockets for several dozen nixie tubes and enjoy to watch your tubes in action.
Project you can find here: https://igg.me/at/nixiedevice
WHAT FOR?
The main function is "good looking".  If you are a nixie tube enthusiast, this project will be the perfect complement for your desk.
HOW IT WORKS
Useless Nixie Device is a simple tube controller with high voltage 170V power supply on board. All digits or characters of the nixie tube are displayed with a constant speed. The device requires 12V power supply.
EXCHANGEABLE TUBE SOCKETS
  • 16 sockets available for dozen different tubes
  • Each socket have same form-factor
  • Acrylic enclosures
  • Easy to assemble and use
  • Dedicated carton packaging
