Interface generator released on GitHub
A project log for Coupled Physics and FPGA Simulation
An open source controller development workflow using OpenModellica for physics simulation and Icarus verilog for controller simulation.
adam-langeAdam Lange 11/20/2018 at 19:280 Comments
I used the coupling strategy once so far.  It worked quite well.  The first time through I hand coded everything.  For the second time through, I'm making a code generator.  At the time of writing, the generator is mostly done.  The generator outputs a python module to be integrated in a cocotb test bench and a modelica model.  I'll be trying to use it soon.
Although it's almost certainly full of bugs, I have the generator up on GitHub: https://github.com/adamLange/hdlModelicaInterfaceGen
