As we know that the water is transported through the pipeline in INDIA and if there is a minor breakage in the pipe the leakage get start which is next to impossible to detect the leakage and repair it almost every part of India water is transported through the Pipelines.According to the survey 30%-40% water is waste because of water transportation. So,we came up with solution regarding this Problem .We have placed a self designed dynamos at different distances of the water pipe as water strikes the blades of dynamo some voltage will generate in all dynamos due to which all voltmeters will show same reading as water is moving with constant speed throughout the length of the pipe. Then water move forward it will strike with one another dynamo and some reading will be shown in the voltmeter..If there is a leakage there will be a difference in the voltage generated in the adjacent dynamos.With the help of micro controller we have connected our system wireless to smart phones and when leakage take place will we get notice and we can easily repair.
Now,
As the water flow the dynamos will move and generate electricity.If there will be leakage it will be detected but if no leakage then also the electricity keep on generating .
Application-
Main Reservoir to Houses
In houses from tank to taps
Using this the whole problem of WATER AND ELECTRICITY BOTH WILL BE DISCARD COMPELETLY.
Ben Nitkin
Anteneh Gashaw
Hello, how is your plan implemented? I am also very interested
