faster sqrt (or so it seems on single point precision)
A project log for mlx90640 sensor works w 800 bytes
Everywhere i read people are excited to get mlx90640 working. here are examples using arduino w 800bytes ram, and 1k with calibrated DEG C
jamesdanielvjamesdanielv 09/19/2019 at 22:410 Comments
i'm working on reducing solve times for sqrt and div that i can not eliminate. currently the times for sqrt of all 768 cells are less than 100000 microseconds. now i'm trying to remove division and where it still is needed reduce time down drastically. for example there are 2 division operations that take most of the time and limit performance of detailed Temp measurement of 768 cells upsampled to 3072 cells at ~0.6 seconds at latest build . still not uploaded as it requires a lot of checks for modes, features and multiple processor testing. but it will be.
ok. back on point reducing sqrt root.
i have discussed this here:
https://hackaday.io/project/167533-faster-speed-how-optimize-math-and-process-tasks
and have implemented the choice to use it in the algorithms for the mlx90640, but i was also able to eliminate one of the sqrt(sqrt(x)) loops from the sensor math. but here is the sqrt function i'm using. it has an error rate average of less than 1%, but with some numbers it could go to 3%. it is more accurate than the original float i found that uses this method. there also is a fast method that corrects for the rounding error but i need to look at that in more detail. this one here is more based on my base 10 thinking.
if USE_FAST_SQUARERT_METHOD will need to be set as true.
float Q_rsqrt( float val ) //a good enough square root method.
 if not enabled in Z_memManagment then it will work as regular sqrt and use math library
  #if USE_FAST_SQUARERT_METHOD == true
   float invertDivide=0.66666666666 ;//   ~1/1.5 rounded down to float precision single float
  long tmp = *(long *)&val;
  val*=0.22474487139;//number that keeps precision detail by keeping remainder. (base 10 thinking. prob                                      //better to think in base2
    long tmp2 = *(long *)&val;
    tmp -= 127L<<23; //* Remove IEEE bias from exponent (-2^23) */1065353216
    tmp2 -= 127L<<23; //* Remove IEEE bias from exponent (-2^23) */1065353216
    tmp = tmp >> 1; //* divide by 2 *
    tmp2 = tmp2 >> 1; //* divide by 2 *
   tmp +=1065353216; /* restore the IEEE bias from the exponent (+2^23) */
   tmp2 +=1065353216; /* restore the IEEE bias from the exponent (+2^23) */
   float offset=*(float *)&tmp2;
    val= *(float *)&tmp;
    return (val+offset)*invertDivide;
  #else
//we do the more accurate but slower method if it is set
  return sqrt(val);
  #endif
