27th September: RF investigation.
A project log for WildDrone Locator
"Safety First!", we often hear. Mounted on a drone, this beacon says "I'm here!" in LoRa language.
mihaivdrMihaiVDR 09/30/2018 at 23:310 Comments
Time is running out.
I have managed to get data from a remote transmitter, but the range is poor. Might be the lack of LOS (Line of Sight) between the receiver and the transmitter, but I suspect something else.
I brought the receiver and the transmitter at close range (that is 10 cm).
The receiver displayed its RSSI: -44dBm.
I moved 3 m away: -57dBm.
I connected them together: -42dbm.
The transmitter should send out 20 dBm.
I fired up a spectrum analyzer at work and conected the RF output through -45dB attenuation. I centered the analyzer on 434MHzwith 100MHz span
Fig. 1: Power output measurement, with 45dB attenuators.
Fig. 1: Power output measurement, with 45dB attenuation.
The marker peaked at -27.98dBm.Let's call it -28. Add 45 and we get 17dBm. Not bad, it migh actually output 20dBm, but the attenuators definitely have some tolerance and the thin coax cable is certainly not loss-less. I bought it from ebay.
Let's try a different coax, maybe this one is of low quality and has high losses.
Fig. 2: Output power measurement, -45dBm attenuation.
With a new coax, the result is very close, but the soldering job at the board certainly dropped 0.2dBm. So the module outputs a decent amount of power and the cable is not as bad as I thought.
Let's see what does the receiver receive. I borrowed a better pair of antennas from a colleague (thank you Marius):
Fig. cx: NA711 433MHz antenna.
Fig. 3: NA771 433MHz antenna.
And I connected it to the analyzer, with no attenuation. I got -3dBm. Quite a loss from all those 17dBm, but still far away from the -44dBm returned by the receiver.
Fig. 3: Homemade antenna and NA711 side by side.
Fig. 4: Homemade antenna and NA771 side by side: -4 dBm.
And I tried several other antennas:
Fig. 4: Two Na771 side by side.
Fig. 5: Two Na771 side by side.
Fig. 5: 2xNa771 - Results: -1.5dBm
Fig. 6: 2xNa771 - Results: -1.5dBm
Fig. 7: 2 x 3DRadio 433MHz telemetry antennas.
Fig. 8: 2 x 3DRadio 433MHz telemetry antennas. Result:
Fig. 8: 2 x 3DRadio 433MHz telemetry antennas. Result:-1.72dBm
Right now I wish I paid more attention at the Microwave course at school. We also had a class for antennas, but only theoretically.
Something doesn't add up. The receiver's antenna gets around -1dBm with the better antennas, but is reports -44dBm.
