Full Featured RC CAR !This is an alpha version, please test it and help (especially to help me painting on papercraft) !https://www.youtube.com/watch?v=weQ9BXCKDfkFeatures :- Controlled by wifi with any phone with the orientation sensor - Very accurate and easy to drive (servo motor for direction) - Use only common and cheap (around 10 $) electronics - No needs of bolt and screws - Upgrade via OTA (Over The Air) - You can use recycle 18650 battery - You don’t have to install any extra software on your phone (web interface) - Configure the car with a complete web interface - Can be connected to WIFI as an Access point or connect to you local network - and more to discover…I've worked a lot on this project and it's not perfect now, but fun to play and usable :)
