To sense the String vibration, I will use an IR refelctive sensor as the HSDL-9100-021 which is analog with the good sensing range (3-20mm) and easy to source.
with a PNP transistor as photodiode amplifier and a 15kHz low-pass filter as polarization tail and 100Hz high-pass filter wich I hope will cancel the 50Hz-60Hz hum.
Now we got an analog signal from the string, we have to square it up. For that I choose to use an guitar effect FUZZ distortion.
A FUZZ distortion is an hard clipping distortion with high gain stage, in this project I will do it with logic gate use in linear mode.
The diodes are here to transforme the last logic gate as a schmitt-trigger.
Here are the coplete schematic for the first try of chiptune analog sound :
all the files can be found on my github.
To be faster I prefered go step by step by choosing a maximum of already created board to keep the soul of the Game boy creator Gunpei Yokoi and his philosophy of "Lateral Thinking of Withered Technology".
with this mantra in mind i will use a gameboy zero AIO board
add the adafuit PAM8302A audio amplifier and the board I design
And solder wire in place of the raspberry pi to power up the board and send audio to the power amplifier
Here are the board in place and working!
I am looking for a better camera to have a good sound to recording!
ARISTIDES Alexandre
