Module Set 6 different thinkness
A project log for Geometer
A Holistic Design Tool for Creating, Communicating and Manufacturing Advanced Human-Scale Forms for Design Pioneers and Producers
david-troetschelDavid Troetschel 03/06/2019 at 15:080 Comments
We generated a module set, but incorrectly made the arm thickness two inches rather than one.
Although not directly compatible it will be interesting to compare designs with these thicker modules compared to the normal one inch modules.
We just had to change the grasshopper script and then regenerate the modules using the endpoint table.
This gives us our one inch output using the grasshopper script.
Now we are adding fillets and making molds. OBJ models will also be made for use in VR.
Since we are really only using modules A-K right now this is going pretty quickly. We are hoping to go into Mindesk soon to test these modules.
