MV1817-Datasheet.pdf
Like an MV1815, but in DIP48, uses 4-bit data bus DRAM, and 9.9375 MHz crystal (half of the more available 13.875 MHz crystal).
Adobe Portable Document Format - 1.05 MB - 03/01/2021 at 03:11
Preview
Download
SAA5246.pdf
SAA5246 datasheet
Adobe Portable Document Format - 629.86 kB - 11/15/2020 at 21:54
Preview
Download
MV1815-Datasheet.pdf
MV1815 datasheet
Adobe Portable Document Format - 1.00 MB - 11/15/2020 at 21:53
Preview
Download
SDA5273-5275_data_sheet(1997-09-01).pdf
SDA5273-5275 data sheet (1997-09-01)
Adobe Portable Document Format - 295.91 kB - 11/15/2020 at 21:55
Preview
Download
SDA5273-3CP_Delta_Specification-Application_Notes(1991-01-27).pdf
SDA5273-3CP Delta Specification Application Notes (1991-01-27)
Adobe Portable Document Format - 325.68 kB - 11/15/2020 at 21:55
Preview
Download
SDA5273-5275_preliminary_data(1997-09-01).pdf
SDA5273-5275 preliminary data (1997-09-01)
Adobe Portable Document Format - 137.09 kB - 11/15/2020 at 21:55
Preview
Download
BROADCAST_DATA_SYSTEMS.zip
A book about Teletext (and a bit about RDS)
Zip Archive - 6.36 MB - 02/27/2020 at 20:02
Download
teletext_spec.zip
Teletext specification in html form
application/zip - 3.82 MB - 02/27/2020 at 01:09
Download
