Light Logic Astable
A project log for LIGHT LOGIC - HIC SVNT DRACONES
Using a LED/LDR pair to form inverting Photonic logic gates. The entire Boolean logic set handled by resistors and diodes! Who'd'a thunk
dr-cockroachDr. Cockroach 10/13/2018 at 21:450 Comments
Second and more traditional circuit being tested.
Again, the video does not show very well that the clock rate is stable.
Just wired up a second astable to make sure the first was not a fluke.
Component level schematic of the final astable circuit.
Led's D1, D2 and resistor R3 are not in this tested circuit.
Below is the first version that was a bit messy.
First test using Light Logic Not gates wired up as a astable multivibrator. Poor video capture but the flash rate is indeed constant.
