Not, Nand and Nor - All in a nut shell
A project log for LIGHT LOGIC - HIC SVNT DRACONES
Using a LED/LDR pair to form inverting Photonic logic gates. The entire Boolean logic set handled by resistors and diodes! Who'd'a thunk
dr-cockroachDr. Cockroach 10/28/2018 at 22:492 Comments
Light Logic
By Mark Nesselhaus aka Dr. Cockroach - October 28, 2018
A demonstration to prove out that diode resistor logic, DRL, can perform inverting Not, Nand and Nor logic functions.
Using a LED and a CdS LDR to form inverting logic gates. The entire Boolean logic set can be handled entirely by resistors and diodes.
I know that all this has been covered elsewhere in these logs but I wanted to get the basics on one page.
Yann Guidon / YGDES wrote 11/01/2018 at 19:46 point
I still believe you can save some resistors and diodes :-P
Dr. Cockroach wrote 11/01/2018 at 20:05 point
Well, the resistor to the LDR can be removed if you do not need TTL compatible output and only need to rely on a hard ground as zero :-) That's how IO functioned :-)
