Things to remember if duplicating Light Logic
A project log for LIGHT LOGIC - HIC SVNT DRACONES
Using a LED/LDR pair to form inverting Photonic logic gates. The entire Boolean logic set handled by resistors and diodes! Who'd'a thunk
dr-cockroachDr. Cockroach 08/19/2019 at 14:530 Comments
Just some things to think about if anyone wishes to duplicate Light Logic.
1 - There is a wide low end resistance value range with CdS photo cells so try to test and match the cells used.
2 - Stray light will kill the Light Logic effect faster than anything else.  Light shielding around the Led/Ldr pair IS required.
3 - Operating voltage is very critical and selection of support resistors is somewhat trial and error.
Light Logic in its current development is still very experimental and requires a lot of hands on adjustments.
