• Preparing for assembly
    Mile4 days ago 1 comment
    DIYTIL305 is made out of three main parts:
    1. PCB - PCB is 0.8mm so that I can easier match TIL305 dimensions (PCB + diffuser). Kingbright APG0603 series of leds is used (0201 Imperial code). Black solder mask is used to provide better contrast of leds with background. Exposed copper traces on PCB as a throwback to original part.
    2. Pins - Machined header pins with broken plastic guard are used. Compatible with breadboards and IC sockets, cheap, accessible, gold plated. Also 1.27mm pin header can be used for lower mounting heights when soldered.
    3. LED Diffuser - Used to make the light from leds more uniform and distinguishable. I will approach to this from three different angles:
      • FDM printing using Red transparent filament (results showed on image below).
        • PROS: Cheap
        • CONS: Low quality of details, post processing needed(layer lines), limited selection of colors
      • SLS printing using transparent resins.
        • PROS: Great quality, possibility of replicating TIL305 diffusor in full detail
        • CONS: Expensive, limited selection of colors
      • Laser cut acrylic (suggested by Dave's Dev Lab). Example of acrylic that can be used showed on image below.
        • PROS: Cheap, Great details(sharp edges), vast selection of colors
        • CONS: Needs special mounting method(3D printed parts just clip on)
    • PCBs are arranged into 2x5 panel for easier assembly.
    • Mechanical prototype for pin header and diffuser testing.
    • Different types of diffusers are being tested.
  • This is TIL305
    Mile10/10/2018 at 21:45 4 comments
    According to datasheet dots on TIL305 are arranged on 0.05"(1.27mm) grid. With that information I can now measure the size of a single dot. On the picture below each increment of scale represents 0.1 mm. It means that single dot is 0.4x04mm. I thought incorrectly that they were 0.6x0.6 (drawing from datasheet is more symbolic than actual representation of the part).
    For my version of TIL305 I will use 0201 leds(0.65x0.35mm) rotated by 45° on 1.27mm grid.
    Display showed on pictures below has marking "KOREA 8418".
  • Before TIL305 there was TIL302
    Mile10/08/2018 at 17:14 0 comments
    While researching TIL305 I discovered TIL302. It shares same package as TIL305 but is configured as seven segment, unlike TIL305 which is 5x7 matrix. I had to get one so here are some pictures:
