ROS finally
01/28/2019 at 09:32 • 0 commentsIn this project log I will describe how I got my distance sensor assembly to work with ROS and how I displayed the scan data using RViz. In addition to this project log I prepared a short video showing the distance sensor assembly performing a 360° distance scan.
Test setup
The test setup consists of:
- a PC running Ubuntu 18.04 with ROS Melodic Morenia installed
- the Sharp IR distance sensor assembly connected to the PC via USB
- an „arena“ made from card board for the side walls and black paper for the floor
ROS
The ROS framework / middleware provides a rich toolset to develop, debug and analyse robotic applications of which my example uses just a small subset. The primary target is to learn how to prepare the distance scan data for use in ROS and once available on the PC how to display the data with the tool RViz. My setup consists of a sensor (IR distance sensor), an actor (stepper motor) and a debug tool (RViz). Data exchange within ROS is done using messages which are sent by publishing to topics and received by subscribing to topics. These messages can either be taken from a predefined set or newly defined if none of the existing are appropriate. Same is valid for topics while the typical use case is to define application specific topics. Thus the distance sensor assembly publishes its gathered data on one topic and subscribes to another topic over which it receives commands to control its behavior. These commands are generated on the PC. Instead of creating a ROS package I chose to use the program rostopic to publish the command messages. For ease of use I wrote a small GUI in python which encapsulates the calls to rostopic for the different commands. The package rosserial provides the interface between both systems and enables the embedded system to publish and/or subscribe to topics. It is integrated as a library into the software of the sensor assembly and used as an executable on the PC.
Embedded System
For the integration of rosserial into my embedded software I took inspiration and source code from the github repository of Itamar Eliakim. Accordingly I converted my MCU project from C to C++ as rosserial is written in C++. Furthermore I am using FreeRTOS to organize the program flow. Like described in a previous project log a distance scan value is obtained by sampling the analog sensor output 100 times at a sample rate of 1 kHz. This is now achieved by timer triggered A/D conversions with DMA transfer of the results to an array in memory. Currently these samples are averaged to provide one distance scan value. A further use could be to calculate statistics in order to evaluate the reliability of the sensor output, which is not the scope of this project. The averaged A/D conversion is transformed to a distance value in meters by using linear interpolation. A look-up table with values from my previous sensor qualification measurements provides in total 40 supporting points for the calculation.
Performing one distance scan takes approximately 450 ms in the current implementation, mainly due to positioning and A/D conversion, which is quite slow. This lead me to design the following measurement procedure as a compromise between angle resolution and 360° full scan duration. In general the stepper motor turns the sensor by 2.25° between each distance scan. The total angle resolution is enhanced to 1.125° by interleaving the scan positions in clock- and counterclockwise direction. Turning the sensor in clockwise direction covers the angles 0°:2.25°:357.75° while the angles 358.875°:-2.25°:1.125° are scanned in counterclockwise direction. Using this procedure it takes 72 seconds to get a coarse overview of the environment which is improved after another 72 seconds.
Measurement results are provided to ROS using the LaserScan message out of the predefined sensor_msgs message set. Its content can be divided into three portions. The first is the header to declare the message for ROS in terms of time stamp, sequence number and most important the frame ID which will be necessary later on for the visualization in RViz. In the second portion the capabilities of the system like scan range (min/max) and time between scans are specified. The last section is where the measurement data goes. An array of float values stores the scanned distances and the variables angle_min, angle_max and angle_increment define between which angles the distance values were taken. I limited the array to 10 scans in order to save memory ressources on the microcontroller as well as to have the scan data quickly available within ROS. Once filled the LaserScan message is published on the topic IR_Scan which is registered in ROS on startup via rosserial.
Finally the embedded system registers a subscriber to the topic start_ir_scan to receive command strings published on the PC using a String message out of the std_msgs messages set.
PC
Several programs need to be started on the PC to get everything working under ROS.
The first step is to start ROS by running:
roscore
Next rosserial needs to be activated by running:
rosrun rosserial_python serial_node.py /dev/ttyACM0
Once started the proper functioning can be verified by listing the available topics:
rostopic list -v
The output of this command shown below contains IR_SCAN in the list of published topics with one publisher and start_ir_scan in the list of subscribed topics with one subscriber meaning everything is started correctly.
Controlling the sensor assembly out of ROS is fairly straight forward as the command rostopic can also be used to publish messages. For example the following command initiates a 360° scan:
rostopic pub start_ir_scan std_msgs/String „CSCAN 1“ --once
A small python program wraps rostopic with different string messages. It offers performing a homing cycle, running a complete 360° scan or aborting the current action.
Shortly after starting a scan, distance data is published on the IR_Scan topic. This can be checked by running:
rostopic echo -n1 /IR_Scan
Which results in the following output:
Visualization
Now that the distance scan data is available within ROS the next step is to start and configure the tool RViz which starts with the following command:
rosrun rviz rviz
Several parameters need to be changed or added to display the measurement data in RViz. First the grid needs to be adapted in terms of cell size and cell count to fully display the measurement data. Next a visualization for the LaserScan message has to be added by clicking on Add at the bottom of the window which will open a list of visualizations. After adding a new entry named LaserScan appears in the list on the left in which several parameters need to be adapted. The Topic has to be changed to IR_Scan, which can be chosen from a dropdown list. Furthermore I chose Points for the parameter Style with a Size of 3 pixels and 180 seconds for the Decay Time to keep the measurement points visible on the screen for more than one complete scan. The final step is to rename the Fixed Frame under Global Options to the frame ID IR_Scan_Map of the LaserScan message provided by the embedded system.
With these settings applied, distance scan data appears on the screen building up a representation of the surroundings of the distance sensor.
Finally if you want to see everything in action you can follow the link to see a small video of my sensor assembly in the „arena“ performing a complete distance scan.
First 360° Scans
10/29/2018 at 10:41 • 0 commentsThe current software implementation allows to perform 360° scans with a rotation angle of 0.45° between two measurements. At each position the voltage output of the distance sensor is sampled 100 times at a sample rate of 1 kHz. The average value of these samples together with the current angle position is transferred via USB to the PC. The incoming data stream is stored in a csv file for later analysis in Octave. A black paper on the floor and walls made from cardboard form the test environment in which the distance sensor assembly can be put at arbitrary positions.
I performed a first scan using this setup with the sensor assembly put into the center position. The generated csv file contains a tuple of current angle and object distance per line [alpha, d] which is the measurement result in polar coordinates. A transformation to cartesian coordinates is necessary to plot the data as a 'map'.
First the angle alpha in degree needs to be converted to radian:
Next the x and y coordinates can be obtained using the following formulas:
The graphs below show the measurement data before and after the coordinate transformation.
This is a very satisfying result for a first try as the generated 'map' reflects the rectangular shape of the test environment.
Putting an obstacle into the test environment leads to the following graph of which two observations can be made.
First the sensor assembly shows a good reproducibility of the distance scans. The two consecutive measurements almost match completely in the range without obstacle. The second observation is about how the distance scan varies in the transition between the obstacle in the foreground and the wall behind leading to larger gaps between the measurements. I will look into that later to see if this information can be used to improve the mapping or to implement an adaptive scan resolution algorithm.
Next on to making the scan angle resolution configurable and to learn how to use this data in ROS.
Qualification of the Sharp Distance Sensor
10/24/2018 at 09:24 • 0 commentsElectrical characteristics
The supply voltage to the sensor is stabilized using a 22 uF capacitor. Anyway there are still voltage spikes visible on the output signal. An RC low pass filter reduces these spikes significantly.
The filtered voltage is fed to the 12 Bit A/D converter within the STM32 MCU and sampled at a rate of 1 kHz. The data sheet states a measurement duration of 38.3 ms +/- 9.6 ms which led me to take an average of 100 samples (=100 ms) for one distance measurement.
At http://sim.okawa-denshi.jp/en/CRlowkeisan.html I found a nice tool to calculate RC low pass filters and analyze their behavior.
Output characteristic curve
The data sheet of the distance sensor contains the characteristic curve of the sensor response to an object at a given distance in front of the sensor. One way is to digitize this curve using e.g. the WebPlotDigitizer and take the extracted data to calculate the object distance. Anyway it is still a good idea to perform measurements on your own to evaluate the sensor characteristic. In addition this provides information how the mechanical and electrical integration as well as the environment affects the measurements.
The setup for this test consists of a black floor and a white paper as a reference object, which was moved stepwise from 1 cm to 80 cm distance relative to the sensor.
At each position the MCU SW takes 10k samples and sends them via USB to a PC. Octave, the open-source equivalent to Matlab, is used on the PC to analyze the measurement data.
With the given setup the distance sensor has the following output characteristic curve:
Below ~7 cm and above ~55 cm the sensor has ambiguous output voltages. This limits the usable measurement range to [7..55] cm. In software I will take this measurement data to implement a look up table and use linear interpolation for the distances in between.
The next step is to implement the motor control in SW to perform 360° scans.
