How it started
A project log for Repurposing a Z80 controller board
A failed attempt to put old hardware to use
ken-yapKen Yap 10/10/2018 at 08:010 Comments
I've sent off for some components from eBay for new projects. They take a while to arrive so while I was waiting I looked for something else in my junk box to work on.
It looks like I salvaged these boards from copiers a couple of decades ago. I don't know if they still work, but there's a good chance that they do and the copier was retired for other reasons. Anyway I have lots of replacement chips if anything on the board needs to be fixed.
Based on the inventory I've started thinking about what to do with it:
What I do not want to do with it:
I don't want make a CP/M computer out of it. If I want to be nostalgic about Wordstar. etc. I can run them in an emulator and it will go faster than any real hardware ever did. Besides the memory spaces aren't conducive to modification to run CP/M.
I don't want to make a clock or something that could be done in much less board space with a modern microcontroller.
There are serial interfaces but I don't want to use them in the final product. I much rather make something that is standalone and has no user interaction other than some switches if necessary.
What I might want to do with it:
The presence of power transistors and comparators on board suggests I could make some kind of controller out of it.
I might have to replace the serial I/O chip with a parallel interface chip. To do this I may have to create a daughter board.
So, until I have figured out its purpose, it might stay a work in progress.
