MegaGRRL - Portable YM2612 VGM Player
Handheld ESP32-powered VGM player, playing tracks from the Sega Mega Drive/Genesis, Master System, and more!
MegaGRRL is a project to make a portable device capable of playing back VGM files targeting the sound chips used in the Sega Mega Drive/Genesis and Master System. It uses the original chips and has a playback engine focused on accuracy and supporting as many features of the VGM file format as possible, all controlled by an ESP32 running FreeRTOS using the ESP-IDF framework.
Demo video of progress so far: https://www.youtube.com/watch?v=YXmvawgrt9U
Currently, work is underway on a second hardware revision to address some shortcomings of the first version. New prototype PCBs have been assembled, a case has been designed and 3D-printed, and the VGM playback core is functional, with progress continuing on a UI.
Hardware
Please note this list is subject to change - project is undergoing redesign
  • MCU: ESP32, specifically the ESP-WROOM-32 module
  • Sound chips: YM2612/YM3438, SN76489
  • Storage: MicroSD
  • Display: ILI9341 240x320
  • Headphone amp: TPA6111A2
  • IO expander: MCP23017
  • DC-DC: 2x LM2735
  • Battery charge: MCP73832
  • LED drivers: 2x PCA9634
  • UI WIP
    natalie07/01/2019 at 00:11 1 comment
    Working on UI stuff, here's a video. Still a lot more to do...
  • Just in case...
    natalie06/25/2019 at 18:29 0 comments
    I did some work on the case! Three 3D printed pieces, and two common lengths of M3 standoffs and screws. It needs a few little things fixed but I'm quite happy with it...
  • blinky
    natalie06/21/2019 at 19:25 0 comments
    i wrote some code to drive the channel status LEDs.
  • Prototype time
    natalie06/17/2019 at 01:23 0 comments
    Getting one of these things put together...
    Tested out the LEDs and they look great!
  • New PCBs arrived
    natalie06/15/2019 at 18:09 0 comments
    The new PCBs showed up! And I immediately found a mistake on one ;_; but it's pretty minor and if it actually affects anything I can fix it with a bodge wire. So far I got the front panel board assembled (don't have a pic on hand, sorry) and the main one about half done, waiting for some more parts to arrive.
    Board pix!
    The power supplies work and the ESP32 boots...
  • Rev.2 PCB almost done...
    natalie05/06/2019 at 19:47 1 comment
    I've been working on the revision 2 PCB and it is now fully routed, and will be done once I fix a few issues and do the silkscreen graphics.
    Also planning to use a PCB for the front panel, with some through-board LEDs to indicate channel status, SD card access, etc. I still have a few more things to sort out with that, but expect at least a screenshot soon. As stated before, EAGLE board files will be available for both once I've tested the new design.
    In the meantime I also did some more testing with using the ESP to generate clocks for the sound chips, and everything works fine. So, officially (I think!), say goodbye to the expensive and hard-to-solder LTCs!
    While I'm talking about things being hard to solder, I want to note that a major design consideration with this project was making it relatively easy to assemble with simple soldering tools. A lot of space could be saved by using finer pitch IC packages, smaller passives, etc, but I stuck with SOs and 0805s because they're pretty doable on a simple pencil iron. I want this project to be accessible to as many people as possible, which would normally necessitate DIP packages for everything, but then it wouldn't fit in your hand, so I think this is a good compromise.
    Anyway, that's all for now. I plan to order a first batch of PCBs at the end of this week, and I'm excited to test them out when they arrive.
  • Revision 2 coming!!
    natalie03/13/2019 at 20:42 0 comments
    I wanted to post a quick update to this. The project is still ongoing despite my silence here! I am currently working on a revision 2 PCB that simplifies things and removes several parts from the BOM, to hopefully make it cheaper and easier to assemble. There were also a few electronic issues with the first PCB, which is why I haven't posted the schematic or board files yet -- I don't want anyone to make the same mistakes I did!
    In the meantime, I got LittlevGL talking to the LCD, and VGM playback is basically perfect at this point. I've also been slowly putting more code into the git repository, but my focus right now is getting this next board revision finished. Once that's done and tested, I can work on getting a UI written.
    Here's a video from last night, testing the use of the ESP32 for clock generation rather than separate LTC6904 chips. This is just hacked onto my current prototype board to validate my design before I order PCBs. I hope to have the new design fabbed and tested by the end of this month.
  • DAC streams are under control
    natalie10/23/2018 at 10:45 0 comments
    Uploaded two more videos again. This time, using two tracks that make heavy use of the DAC stream control subset of the VGM specification. Enjoy! Links to the artists are in the video descriptions, so go check them out if you like FM synth metal stuff~
  • More videos
    natalie10/20/2018 at 18:01 0 comments
    I put a couple more videos on YouTube today:
View all 9 project logs
mensinhl wrote 2 days ago point
Great, i like it. please where can i purchase one of this hardware...
Sebastius wrote 08/16/2019 at 21:09 point
Hey on the Git repo is only the frontpanel, can you please share the mainboard schematic/pcb too? I want to sink my teeth in it.
Coin Feeder wrote 07/24/2019 at 13:46 point
I'd take a fully assembled one every day :)
interzone wrote 07/08/2019 at 17:03 point
Would love to grab one of these if made available!
jensma.de wrote 07/06/2019 at 22:37 point
I'm drooling! I need this in my life! Are you planning on selling kits on tindy or elsewhere?
natalie wrote 07/08/2019 at 06:18 point
not sure about kits - it's almost completely surface mount (although i tried to use 0805s and sot23s everywhere, so it's pretty entry-level smd stuff). however, i am considering selling assembled units if there is enough interest.
Jonas wrote 07/08/2019 at 14:53 point
Hello, I'd be interested to buy a kit as well along with an enclosure depending of the build quality (otherwise I can make my own). I'd like to use it along with my Yamaha CX5MII for maximum FM goodness
Sebastius wrote 07/06/2019 at 19:54 point
Can you please share your schematics/board files/code? Even though its incomplete, it will be fun to experiment with.
natalie wrote 07/06/2019 at 22:09 point
working on getting schematics cleaned up and posted today. just committed the front panel stuff a moment ago. check the git repo link in the left column
Quetzalcoatlus wrote 07/06/2019 at 11:41 point
Wow never had a Genesis this sounds way better than anything i recall the NES or SNES ever putting out but it's been a while 😆
