SWR bridge
A project log for Si5351 HF Antenna Analyzer
HF antenna analyzer using Si5351 as signal source, resistive swr bridge and ESP32 or Arduino as the brains
biemsterbiemster 10/22/2018 at 14:402 Comments
Today I built the SWR bridge on the breadboard, and adapted the arduino sketch to read the FWD and REV voltages on two analog pins.
The SWR bridge design is given in the following schema, and taken from an antenna analyzer build by the NJQRP club. A link to the article is given in the links section.
| chose this design solely because of its simplicity (only resistors, caps and diodes). The analyser in the article also uses an op amp to boost the signal on the FWD and REV ports, and to counter the low impedance on the A/D converter used in their design. In my case the input pins of the arduino have a high enough impedance and the signal should be significant enough to get at least some reading, so in this stage I'm omitting the op amp for simplicity.
The FWD and REV ports are connected to arduino pins A0 and A1 respectively, and the SWR value is calculated using SWR = (FWD+REV) / (FWD-REV).
The breadboard with the arduino, si5351 and swr bridge looks like this:
I know it will give horrible performance on such a board, but i just wanted to see if the concept works.
The swr_sweep.py script is also adapted in the repo, and when i sweep the 27-29MHz range the swr bridge is reporting a standing wave ratio between 3.5:1 and 4:1. Looks promising!
Next i have to find an antenna or so with a known resonance frequency, and test if this little contraption can find the sweet spot.
dwHacks wrote 11/16/2018 at 20:13 point
This is exactly what I've been looking for. So many of the HF antenna analyzers don't use the Si5351, and I happen to have an extra one on hand! Any update on testing accuracy?
biemster wrote 11/19/2018 at 20:59 point
No not yet, I'm still looking for an antenna/load with known swr, since I don't have a professional analyzer. But this is my top project at the moment, so there will be an update soon for sure.
