There is many Board as training Board of NXP Microcontrollers. But many of them contain wary low component for using abilities of these MCUs. I use a lot of different modules and peripherals to use all of abilities of NXP MCUs. This Board is one of the best offer for Starting of ARM training. Some of this Board abilities: 1)ARM Cortex-M3, LPC1788FBD208 2)GSM/GPRS Module M95 3)Touch Screen Controllers 4)ER-TFT050-3 TFT LCD 5)Local Interconnect Network (LIN) physical interface for connecting to OBD of vehicles. 6)BUZER 7)9 pcs of bottom switch’s 8)CLRC66302HN NFC controller 9)ESP8266MOD WiFi Module 10)LIS3DETR ±2g, 4g, 8g, 16g acceleration sensor 11)TDA8026ET an interface for addressing multiple smart card for Point Of Sales (POS) terminal. 12)Speaker and Audio controller 13)USB port 14)S25FL164K0XMFI011, MEMORY, SPI FLASH, 64MBIT 15)IS42S32800J-6TL - 256M, SDRAM 16)Micro SD Slot For more information and giving files contac
There is many Board as training Board of LPC NXP Microcontrollers. But many of them contain wary low component for using abilities of these MCUs. I use a lot of different modules and peripherals to use all of abilities of LPC NXP MCUs. This Board is one of the best offer for Starting of ARM training. Some of this Board abilities: 1) ARM Cortex-M3, LPC1788FBD208 2) GSM/GPRS Module M95 3) Touch Screen Controllers 4) ER-TFT050-3 TFT LCD 5) Local Interconnect Network (LIN) physical interface for connecting to OBD of vehicles. 6) BUZER 7) 9 pcs of bottom switch’s 8) CLRC66302HN NFC controller 9) ESP8266MOD WiFi Module 10) LIS3DETR ±2g, 4g, 8g, 16g acceleration sensor 11) TDA8026ET an interface for addressing multiple smart card slots in a Point Of Sales (POS) terminal. 12) Speaker and Audio controller 13) USB port 14) S25FL164K0XMFI011, MEMORY, SPI FLASH, 64MBIT 15) IS42S32800J-6TL - 256M, SDRAM 16) Micro SD Slot It is manufactures and completely tested.
6) BUZER
13) USB port
16) Micro SD Slot
